Re: Starting to get more confused
What type of tests are you using? Drops or strips?
With a CYA of 0, you need to get your FC level up to 10 and keep it there...testing 2-3 times per day (morning / noon / evening) and adding chlorine as needed to keep the level up to 10. Keep your pump running 24/7, backwashing/cleaning filter as needed...probably daily, if not more often than that.
The aeration should help lower your TA, which you DO need to bring down...WAY down...somewhere from 90 -120 is ideal. Your pH is OK for now. It's at the low end of normal...just keep an eye on it.
Calcium Hardness looks good.
Sherra
Kershaw County South Carolina
(previous AG pool owner)
