Thread: Best guess question
    May 2013
    Concord,ca
    Default Best guess question
    I see the best guess but I am trying to properly read it.
    1. I have a cl. reading of 3 which tonight I will raise with bottled chlorine
    so I understand the min. 3, max. 6 but the shock 15 and +shock+ 30 , what is that? don't know what it means. Please advise, Dave
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: Best guess question
    "shock" is when you have a problem such as algae or some higher than normal chlorine demand (especially overnight). +shock+ is when you have yellow/mustard algae since that is harder to kill.
    May 2013
    Concord,ca
    Ok now since 15 is for green and 30 is for mustard is that saying double the shock?
    May 2013
    Northwest Indiana
    It's saying that's the level of chlorine to maintain in your pool... If you are at 10ppm now, you need to add 5 to get to 15 or add 20 to get to 30ppm. So it is double the level of fc but you do not necessarily double the amount of chlorine you add.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
