Newbie65
...I checked my alk this morning and it was at 170. I will add the acid then the bleach and check in 2 hours.
I usually wait about an hour after dosing with one before adding the other.
Hopefully, this will get me on track. How high do I need to keep my TC readings and for how long?
You need to get your Free Chlorine (FC), not Total Chlorine (TC), up to shock levels, test frequently (like 3x per day if you can), and add more bleach after each test to return the FC to shock level. You can use "Ben's Best Guess Table" to determine the shock level for your pool but it's a function of the amount of CYA you have in the water. So, you're going to have to get more CYA reagent or take a sample to the pool store to have it tested for CYA. In the interim, it will probably be OK to use 15 ppm as a guestimate. As Michael said, it will take about six gallons of 6% bleach initially to get to 15ppm. You'll need to keep bringing the water to that level of FC until you hold FC overnight. It will probably take at least several days.
