Thread: CC test question
    Bowling Green, Kentucky
    Default CC test question
    When testing for CC, is any change in color supposed to happen immediately? In my tests, after the five drops, the tube stays clear 99 percent of the time, but if I don't empty it right away, maybe 10 seconds or more later it'll get a slight pink cast to it. One drop always clears it, so far.
    Default Re: CC test question
    usually if you have cc, it will show right away. If it shows later, and one drop clears it, then even if you do have cc, it's only .5, which is not a big deal.
    Thank you Janet.
    Hoskins, Nebraska
    Quick question-- having a brain blurp and can't remember right at the moment. If you use 10ml of water you multiply the drops used times .5. To get a more accurate reading (under .5 CC) you fill to the 25ml line- run the test the same way, but can't remember what number you multiply the drops used times----- is it .25?? My brain, or what's left of it is telling me it probably should be .125, but can't remember exactly at the moment. Last year my CC run at .4 all summer - which Ben said was acceptable. No hurry- just need my brain refreshed momentarily . Thanks!
    Sincerely,
    Donya (huskerfan)
    If you use 25ml, each drop indicates .2 ppm (5 drops = 1ppm).
    Hoskins, Nebraska
    Smile thanks Carl
    Thanks Carl- I thought it was possibly you who posted last year how to test CC below .5 by filling to 25ml, so was hoping you'd reply. I laid in bed last night thinking about this, sleep is over-rated anyway, lol, and concluded too that it must be .2 per drop since I tested at .4 all last summer. Thanks for confirming this for me. My pool's running .4 again this year. All of my chemical levels are consistent from last year, and the amounts of bleach I use and muratic acid are also consistent. Thankfully most of you don't have to deal with iron like us in NE, but it's under control, and like your signature says: it truly only does take a couple minutes a day to keep crystal clear water! Thanks again for all you moderators do, and the countless hours you put in for all of us!
    Sincerely,
    Donya (huskerfan)
  1. CH Test Question
    By iwannapool in forum Dealing with Alkalinity and Calcium
    Last Post: 05-31-2007, 03:48 PM
  2. CYA test question
    By oasisdave in forum DPD-FAS based testing
    Last Post: 07-14-2006, 08:10 AM
  3. First test and a Question
    By vchords in forum DPD-FAS based testing
    Last Post: 06-20-2006, 03:55 PM
  4. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
  5. 233 kit - CYA test question
    By vanhout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-17-2006, 10:21 AM
