Results 1 to 10 of 15
Thread: Saving electricity - replacing an old pump/motor
    mas985's Avatar
    Pleasanton, CA
    Default Re: Saving electricity - replacing an old pump/motor
    Full speed is 14.6 Amps @ 115V = 1.7 kw and low speed is 4.7 amps @ 115V = 540 Watts. In this case, the pump uses a bit more in power than the breaking HP would suggest. The reason for this is that the efficiency is a bit less than the Northstar but still a fairly efficient pump. Better to use amps * volts to calculate power.
    Note that this is an up-rated pump which would be identical to the 3/4 HP full rate. Either way it is probably more than enough pump.
    You should also double check the voltage requirements. It may be able to operate at both 115v & 230v but the title says 230v while the details say 115v.
    Mark
    Long Island, NY
    I'd really like to understand how these motors work in general ...
    So a standard motor (under reasonable conditions, i.e. while hooked up to pool) will always run at maximum power and constanly draw the rated amps ? Even if the mechanical resistance of the pump varies due to e.g. a more or less clogged filter the amp draw is the same ? I am not questioning it, just want to understand the basics ... This would mean that the pump "tries to get the maximum flow it can achieve at the given head" and consumes always a constant amount of energy per unit of time.
    I am trying to calculate cost saving / ROI for various replacement pumps and want to model actual consumption.
    Regarding sizing the pressure gauge at the filter shows 15 psi (35 ft of head), so if I add suction side head of 8 ft I am at 43 ft of head - does that make sense ? The pipes around the filter and in the ground are all 1 1/2 inch PVC so I should not go higher that 44GPM which is fine for the 8-10 hour turnover.
    Pump options are (some might be a little crazy)
    - a regular EE pump, .5 HP such as the Northstar NS4005 although flow at 40 ft of head would be a tad too high for the plumbing
    - a two-speed pump such as the smaller Pentair WhisperFlo WFDS-3
    very tempting - a 115V - means I don't have to run new cables.
    - PMSM based pumps such as Pentair IntelliFlo 100, 160 or the big one. They are expensive but might work out IF the energy savings are close to what Pentair claims. Do you have any idea how to estimate this ?
    Patrick
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by pauster
    More or less. The current will change slightly (<10%) with load but this can only be measured so as a first order, just use the rated amps. Also, the impeller of the pump is designed such that the motor operates near at the service factor load (i.e. full load)
    The biggest impact to the pump with load changes is it's efficiency. How much work it does vs. the braking HP (BHP = HP * service factor) or energy use. Generally, if you are in the range of 45-65 feet of head, the energy efficiency of the pump may vary from 40% to 50% peaking somewhere in the middle depending on the HP of the pump. BHP efficiency can be determined by (GPM * Head (ft))/(3960*BHP). Energy efficiency is similar = (GPM * Head (ft))/(5315*KW)
    Energy efficiency is a bit less than BHP efficiency depending on the pump.
    So you might ask where does the extra energy go. Heat! This is why a pump will burn out if loaded too lightly or heavily.
    Yes but remember without a suction measurement, this is only approximate but probably within +- 3 ft. Also, if you have pipes plumbed in parallel, they can each handle 44 GPM. So depending on design, the flow could be more.
    Ah but this is the funny thing about hydraulics. If you reduce the pump HP, the head the pump sees is reduced as well. Here is a good rule of thumb:
    RPM ~ GPM
    Head ~ GPM^2
    BHP ~ GPM^3
    Head ~ BHP^2/3
    ~ means proportional
    So
    New head = Old Head * (New BHP / Old BHP) ^ 2/3
    You would need to get the pump curves and amp usage for each of the RPM settings. Perhaps on their web site.
    Patrick
    See above.
    Mark
    Long Island, NY
    Arrow Re: Saving electricity - replacing an old pump/motor
    Hi Mark
    this was most helpful (I am a SW engineer so I lenjoy this kind of thing ) it is now MUCH clearer how thie pieces fit together.
    The Intelliflo curves can be found at pg 47 of
    http://www.pentairpool.com/misc/owne...User_Guide.pdf
    So if today I have 40 ft of head at 40 GPM (my return is a single 1 1/2 inch PVC pipe; the previous owners deactivated the other 1 1/2 inch return; the piping around the pump and filter is a single 1 1/2 inch pipe, too, coming from 2 1 1/2 inch suction side)
    If I understood yo correctly the power (KW) is proportional to GPM*Head, so I approximate .4 kW in the diagram for 35 GPM/30 ft of head.
    GPM Ft head KW
    40 40 0.597
    35 30.625 0.400
    30 22.5 0.252
    25 15.625 0.146
    20 10 0.075
    15 5.625 0.031
    10 2.5 0.009
    If I run this baby 18h at 15 gpm and 2 h at 35 gpm per day, I'll use 41 KWH per month instead of 410. In a 5 month season (yes, I use the pool if the water is warmer than 67 deg here on Long Island, NY) . At $.195/kwh that's a savings of $358 per season !
    Can this be true ?
    Patrick
    mas985's Avatar
    Pleasanton, CA
    Unless I got your current pump curve wrong, I think your flow today with the Hayward pump is closer to 60 GPM based upon the Hayward pump curve @ 45ft of head (rounded up): http://www.haywardnet.com/products/d...m?ProductID=10
    That Hayward pump has a BHP of about 1.24 because it is a max rated pump.
    I am not quite sure how you did your calculations for the new pump but this is how I would do it. You current plumbing is defined by the head and GPM no matter what type of pump you use (power formulas cannot be used between pumps because efficiency curves are different). So first you need to iterate this formula for a solution that falls on the new pump curve:
    New GPM = 60 * sqrt (New Head/45) where new GPM & Head must fall on new pump curve.
    So for the intelliflow here are my estimates for each of the RPM settings:
    3450 RPM - 85 ft head - 82 GPM - 2.6 KW - 31 GPM / KW
    2070 RPM - 30 ft head - 50 GPM - 0.6 KW - 83 GPM / KW
    690 RPM - 3.4 ft head - 16.4 GPM - Hard to read power
    Each of these should fall on their respective curves.
    This pump has a pretty high head at the top setting so you may not use it much. It also costs a lot so the payoff may be longer than a two speed pump.
    A 0.75 HP Wisperflow would have the following economics:
    High Speed - 55ft Head - 65 GPM - 1.7 kw - 38 GPM / KW
    Low Speed - 14 ft head - 33 GPM - 0.5 kw - 66 GPM / KW
    Not as good as the other pump but payoff may be sooner.
    Mark
    Long Island, NY
    Hi Mark,
    now what happens in 1 1/2 inch pipe where it supposedly gets ugly beyond the 42 gpm ? If I had over 60 gpm going through that pipe today the velocity of the water could be detrimental to the piping ?
    Just looking at the smallest pumps availabe - I was aiming for about 40 gpm at 40 ft of head. Most pumps go beyond that.
    Of course if I am getting more than 40 gpm today (say 60 gpm) then my new head at 40 gpm would be lower: 40 / (60/40)^2 - right ? So head at 40 gpm is around 17.8 ft ?
    Patrick
    mas985's Avatar
    Pleasanton, CA
    Hi Mark,
    Theoretically, it could slowly wear out the interior of the pipe but I have never heard of a case.
    Right so most single speed pumps will be well beyond that. But as the calculations showed earlier, multi-speed pumps at lower speeds should be in that range. Target a 3/4 HP 2-speed or multi-speed pump and you should be OK. The Whisper flow 3/4 HP I did the calcs for earlier should be about 33 GPM at low speed.
    Also, sometimes it is good to have a high speed to mix up and distribute chemicals before a quick swim.
    Patrick
    See above for answers
    Mark
    Long Island, NY
    Hi Mark,
    I have your your input for some more extrapolations ... so for a sanity check (another one )
    Pentail IntelliFlo
    GPM Ft head KW gpm / kw (assume about const. efficiency per manuf info)
    85 86 2.9478 29
    65 50.7 1.318 49
    50 30 0.600 83
    45 24.3 0.437 103
    40 19.2 0.307 130
    35 14.7 0.206 170
    30 10.8 0.130 231
    25 7.5 0.075 333
    20 4.8 0.038 521
    15 2.7 0.016 926
    Pentair 2 speed
    high = 3450 rpm: 65 GPM, 1.676 kW, 39 gpm/kw
    low = 1725 rpm: 35 GPM, .54 kW, 65 gpm/kw
    The Pentair 2 speed would save me $208 per season, the Intelliflo $372 (see attched zipped Excel spreadsheet)
    So it's just a question of how much the pumps cost and how long it takes to pay for itself.
    I found the pentair for $421 online plus say $130 for a 2 speed switch - does that sound reasonable ?
    If I can get the Intelliflo for $900 (supposedly, but I have to confirm with the dealer) then it makes more sense, if it costs more, the Pentair is what I'll use - but I'd have to run 230V to the pump (.
    Thanks again for your patience !
    Patrick
    mas985's Avatar
    Pleasanton, CA
    I thought the Intellifo only had 4 RPM settings, you are showing 10. Are there more than the head curves show?
    Also, remember that these calculations are approximations so I would not expect less than 10% error. You may be splitting hairs when it comes to costs.
    I understand you want to save the most money but the Intelliflo is relatively new pump so it is not well time tested and has many more parts to fail. Keep that in mind when doing a cost benefit analysis.
    You might want to query the forum again to see if anyone has one.
    Mark
