Re: How long does it take? Is there a way to know?
I am using a test kit from here, and I like it. CH is 3.6, PH is 7.2, alk is 185. The program says to add 5.77 cups of acid. I think adding this much acid will lower the PH also. After adding the acid, how long should I wait to recheck and add soda ash, if needed? Thanks for help with this.
Dan
18 foot above ground vinyl lined pool. The pool has an expandable liner that drops to 5 foot deep for about 9000 gallons of water.. It is surrounded with a raised deck about 1/3 of the way around the back of the pool.
