Re: How long does it take? Is there a way to know?
If I choose to use Borax to increase PH (I think I will since it does not raise ALK) is the dosage the same amount. I do aerate every night with a pool cooler like this http://www.poolmister.com/product/inground-pool-mister/ but it does not seem to increase PH. I use it from about 6pm to 6 am. As far as adding acid, how much would you suggest and how often until I get in range?
Dan
18 foot above ground vinyl lined pool. The pool has an expandable liner that drops to 5 foot deep for about 9000 gallons of water.. It is surrounded with a raised deck about 1/3 of the way around the back of the pool.
