Thread: 15x48 pool pump help
    Jun 2013
    W Virginia
    Default 15x48 pool pump help
    Hi my pump is going out and am wanting too replace it my pool is an intex 15x48 above ground pool the pump im wanting to get says its for a 24' round above ground pool will this work with my 15x48 round pool please help asap thanx
    Jul 2012
    Mexico, Missouri
    Default Re: 15x48 pool pump help
    If it is an Intex/Krystal Clear pump/filter that you are looking at buying, there should be no problem hooking it up.
    If it's meant for a permanent install AGP, you may have to find/make adapters, but there should be no reason why it couldn't work.
    Can you provide a link to the pump you are wanting to buy?
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jun 2013
    W Virginia
    Jul 2012
    Mexico, Missouri
    Check my signature. You are buying the same pump and filter I've had for about a year. Works great on my 15' x 48" Intex.
    If your pool has the small hose clamp style fittings, Check with amazon to see if the large pool fittings and valves are included along with the 1-1/2" hoses. You will need them, as the 1-1/4" (hose clamp style) hoses will not work with this pump.
