Check my signature. You are buying the same pump and filter I've had for about a year. Works great on my 15' x 48" Intex.
If your pool has the small hose clamp style fittings, Check with amazon to see if the large pool fittings and valves are included along with the 1-1/2" hoses. You will need them, as the 1-1/4" (hose clamp style) hoses will not work with this pump.
