Thank you -- this is very educational!
I wonder if exit velocity can be improved by changing the fitting at the return -- maybe narrowing the stream of water and aiming it to go more directly across the pool. Once we have the larger pool set up, we may try experimenting a bit (we're high on DIY capabilities, not so high on $$ here).
