Re: Green Hair????
readytoscream
I'll take the sample in the morning to another town's pool store and get the results posted soon as I get back home. Sorry!!!! I really have learned alot from you all. I thought I was doing good!!!!
You are doing good but there are seveal things going on in your pool and they need to be addresed one at a time and in proper order. Until they are I would not let your kids or anyone else swim in the pool. It just isn't safe! If the pool is still green or cloudy it DEFINITELY is not safe! Get the water tested and find yourself a decent test kit. the aquachem 6 way is the best you are going to find for cheap. If you can get an Taylor Technologies K-2006 you can test everything yourself except for the copper. It is not a cheap kit and will cost in the neigborhood of $70. Taylor also makes a stand alone copper test kit for around $20 but if you can find a pool store that can test for copper and iron separately, or just the copper, you really don't need to spend the money on it since we hope to get the copper problem under control and hopefully it won't come back with proper maintenance (which means adding the maintenance doses of Keetrol or another seqeuaterant as recommended on the bottle AND NEVER ADDING A COPPER ALGECIDE AGAIN. There are other and better ways to deal with algae, which should not come back if you care for the pool properly anyway)
