Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 42 of 42
Thread: Green Hair????
  1. #41
    North Alabama
    Smile Re: Green Hair????
    I am using pucks and cannot right off hand remember the cya results. Thanks for all you have done to help me with this. I know I was very sketching in my details to say the least. My cya results where 33
  2. #42
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Green Hair????
    Perfect! Just keep tabs on your pH ( between 7.2-7.6), chlorine (for right now about 3 ppm, when the CYA gets higher you will have to raise the chlorine levels to compensate), and your CYA (when it gets over about 60 ppm you should stop using the tabs and just use bleach to chorinate or you will have to drain and refill once it gest above about 80 ppm)
    ENJOY THE POOL AND HAPPY SWIMMING!!!!! YOU DID IT!!!!!!!
