Thread: LITTLE ASSISTANCE W.MOM, GEEK, HEY please
    May 2013
    Concord,ca
    Unhappy LITTLE ASSISTANCE W.MOM, GEEK, HEY please
    Ok I checked the ole fiberglass pond as I had a small spot of algae. I have been keeping it up but now my readings are as follows
    cl. 1.0
    ph 7.8
    ta 80
    stab is at 35
    ok I will add all the chart says to add, but I am constantly adding muriatic..not that I mind I am careful. but my TA is always at 80. BTW best guess is 3-6 on chlorine which of course I am not. Should I just add stabilizer now and tonight around 9pm add the chlorine/bleach and acid? Thanks Dave
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    BigDave's Avatar
    Default Re: LITTLE ASSISTANCE W.MOM, GEEK, HEY please
    How much acid do you usually add and how low does it take the pH? Do you regularly add make-up water or do you have an automatic leveller? What's the pH of the fill water?
    May 2013
    Concord,ca
    Dave, I normally add 15 oz, it take about 3 days or 4 and I have an automatic water filler my fill water which is my city water is 8.0 or more. That's as high as my k 2006 goes. How do I get the xact amount? Geesh! I never knew it was that high!
