Thread: Changing Power Cord
    Default Changing Power Cord
    My pump motor has the 3 prong twist plug and Id like to change it to a standard 3 prong plug. Checked at my local Home Depot and all they have are medium duty replacement cords(14g). My pump is a two speeder with the highest being 8.8amps @ 115v. If Im figuring correctly thats 1012 watts, so as long as the medium duty cord will handle that wattage Im thinking I should be ok. Any thoughts?
    Honesdale PA
    Default Re: Changing Power Cord
    14 gauge copper is 2.58 ohms per 1000'. For a 10' cord, that's a .45 volt drop at 8.8 amps. At 8.8 amps that's about a 4 watt loss. No big deal in my opinion. However I would check for any hot spots on the plug, cable, and motor connections to be sure. Go for it. I know, someone is going to kick in about local building codes etc.
    Yeah. Check your local building and electrical codes....
    Now Al is happy!
    Rehoboth, MA
    I'm curious why you want to go to the regular 3-prong plug. Home Depot sells the twist-lock outlets so it shouldn't be any more work to change the outlet (in fact probably less) instead of the cord.
    Peter
  1. Anyone ever repair power cord for Aquabot Turbo T?
    By LizT111 in forum Pool Equipment & Operations
    Last Post: 05-29-2011, 05:03 PM
  2. SC-60: How to pull the power cord
    By CAL7 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-29-2011, 08:12 PM
  3. changing pool pump cord
    By pcasey61 in forum Pool Equipment & Operations
    Last Post: 03-20-2009, 06:08 PM
  4. Pool pilot flow sensor cord
    By Tominthedesert in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-26-2008, 05:20 PM
  5. Filter pump cord length and some other electrical questions?
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-20-2007, 10:38 AM
