Results 1 to 10 of 152
Thread: Bromine Chemistry Question
    Default Re: Bromine Chemisty Question
    Some algaecides cause foaming issues in pools.
    It is generally best to not try and combine chemistry advice from a local pool store and from here. It will often conflict and you can end up with a mess in your pool. Best to pick one or the other to take the advice from. Hope that makes sense!
    Jul 2013
    Northern Illinois
    Yes, it does make sense, but Dave and Ben said to go ahead with their products for today but the pool store did the old switcharoo on algaecides. At least I didn't use the copper one! I AM trusting the forum. Absolutely! Thanks!
    Quote Originally Posted by BromineUser View Post
    That was a GREAT decision! You definitely don't want copper in your pool!
    Jul 2013
    Northern Illinois
    My water is now clear and no longer brown-tinged! The pool store is done now with the "complimentary" chemicals. They had me add one more quart of Pool Magnet Plus and they say it's time to add: 25 lbs of chlorine (they did a chlorine demand test). The chemicals I have added to my new water are: 2/3G of MA, 4 quarts of Pool Magnet Plus, 1 quart of Inhibit Back-up (chemical composition on page 3) and 1 quart of 60% polyquat.
    What I need to know is what YOU say I should do next. Also, I do plan on adding borates whenever you say it's time.
    My numbers are:
    pH 7.4 (7.3+)
    TA 180 (Alex test says 180, Leslie's test says 150-160)
    CH 100 (Alex test says Tot. Hardness 164, Leslie's test says CH 130)
    Thanks!
    Do *NOT* dump 25# of chlorine in there -- it will 'break' some, if not all of the HEDP, and could drop any metals out on your liner. Do *NOT* raise the pH (add borates) yet.
    Have you used the polyquat? Can you get more? Can you get DE locally? Can you easily get calcium hypochlorite locally for a reasonable price (< $4/lb)?
    (By the way, thanks for the comparison test results -- that's very helpful info for us. If you can, once you begin adding CYA, and do CYA testing, I'd love to see a comparison on those test results.)
    Jul 2013
    Northern Illinois
    Thanks, Ben.
    I used 32 oz of polyquat last Friday that I paid $30 for at Leslie's. In-The-Swim is about 25 minutes away in West Chicago, IL and they sell quarts of polyquat for $23.00. So yes, I can get more polyquat locally that is cheaper than Leslie's.
    Home Depot has 25# bags of DE for $20.00. Should I get some and add 2 cups per day?
    Calcium hypochlorite appears in lots of "bag-o'-shock" products. Is that what you mean? If so, I wouldn't know how to chose from one bag to the next. Is there a specific chemical composition that I should look for?
    All I have on hand in terms of chemicals are a 50# bucket of 99% dichlor from Sam's Club and a few gallons of 12.5% bleach. I don't plan on adding CYA, borates, or anything else until you tell me to!
    Randy
    I included links to all three products, but it looks like the polyquat might be the only one you want to buy from Amazon.
    Kem-Tek 60% polyquat @ Amazon
    Nava 60% polyquat @ Amazon
    In the Swim 12 x 1# cal hypo
    Diatomaceous Earth (DE) pool filter powder, 25lbs
