Re: Bromine Chemisty Question
My water is now clear and no longer brown-tinged! The pool store is done now with the "complimentary" chemicals. They had me add one more quart of Pool Magnet Plus and they say it's time to add: 25 lbs of chlorine (they did a chlorine demand test). The chemicals I have added to my new water are: 2/3G of MA, 4 quarts of Pool Magnet Plus, 1 quart of Inhibit Back-up (chemical composition on page 3) and 1 quart of 60% polyquat.
What I need to know is what YOU say I should do next. Also, I do plan on adding borates whenever you say it's time.
My numbers are:
pH 7.4 (7.3+)
TA 180 (Alex test says 180, Leslie's test says 150-160)
CH 100 (Alex test says Tot. Hardness 164, Leslie's test says CH 130)
Thanks!
