Results 1 to 10 of 152
Thread: Bromine Chemistry Question
    Jul 2013
    Northern Illinois
    Default Re: Bromine Chemisty Question
    After adding 6C dichlor and waiting an hour:
    PM:
    FC: 5.4
    CC: 0.8
    pH: 8.0
    TA 200
    CH: 90
    CYA: 0
    AM: (I did not get up at dawn but the auto-cover was closed)
    FC 5.0
    CC: 0.8
    pH: 7.4 (but if I let it sit for a while it rises to 8.0 so maybe that was issue last night?)
    TA: 200
    CH: 90
    CYA: 0 (but the mixture looked cloudier than last night)
    Read the pH when you do the test instead of letting it sit. Also, no need to test the CYA so often or you will run out of reagents. Once per week while you are using dichlor is probably plenty often enough.
    Jul 2013
    Northern Illinois
    Thanks! That helps. Now I just need to know what to do tonight! :-)
    Quote Originally Posted by BromineUser View Post
    FC 5.0
    CC: 0.8
    TA: 200
    CH: 90
    Leave the cover off, if you can. And add some muriatic acid, to lower the pH.
    Read these pages:
    http://pool9.net/ma/ (Using muriatic acid safely)
    http://pool9.net/alk-step/ (Step by step guide to lowering alkalinity)
    Jul 2013
    Northern Illinois
    Will do, thanks. I was wondering if TA was next...! Should I just use the pool calculator for maintaining my FC for now, rather than bugging you about it? If so, I will continue using dichlor until I get a CYA reading (unless you tell me otherwise).
    Really, what I want is for you to sort of keep it in your head. That sounds a bit hard, and probably is, right now. But you'll get use to it, and doing so will make things easier.
    As far as chlorine goes, 10% of your CYA will keep you algae-free. You can go lower, if the pool has no sign of algae.
    Use the poolcalculator as needed, but "use" it, instead of letting it "use" you.
    Jul 2013
    Northern Illinois
    Thanks for the reply although I don't know what you want me to keep in my head. Figuring out the amount of dichlor or bleach I should add?
    Anyway, I went to Leslie's to get more MA (they are cheaper than anywhere around here believe it or not: $11.79/2G of 31.45%) and took in a water sample. They have the same pH and FC numbers as I do but again we differed on TA (I said 200, they said 170) and CH (I said 90, they said 150). You said you liked to see comparison numbers, so there you go.
    I added 3/4G of MA to aim for pH 7.0 (I am going to use my OTO for ph because it goes to 6.8 vs the K2006) I will check pH in 4 hours and add more MA if needed. When the pH gets down, I will aerate by 2 fountains and the step spa-jets.
    What I meant, by "keep it in your head", is that if you add doses, and then test, you'll get to the point where you know what a reasonable dose of chlorine, acid, or alkalinity is for YOUR pool. That way, if your chlorine is low or your pH high, you can simply add the right dose -- learned by experience -- rather than running into the house (or for your smart phone -- and handling phones while you're handling chlorine tabs is NOT a good idea!!) and checking the calculator.
    New forum members sometimes get fixated on various calculators, and become dependent on them, which prevents them from reaching that plateau where, 90% of the time, you know the right dose as soon as you see the test results.
    Jul 2013
    Northern Illinois
    While we're waiting for TA to adjust, I have a few questions for Ben. You had me purchase 4 qts. polyquat and 12# of calcium hypochlorite. I am not sure when I am supposed to use them. In years past, the "pool store" had me do a weekly maintenance of 3 lbs "shock", 6 oz polyquat eq., 6 oz clarifier, and 6 oz HEDP eq. I know the clarifier is out with BBB method, but what about the polyquat, the HEDP, and the calcium hypochorite? Do I do any of these on a maintenance/regular level? If not, I am sure you asked me to purchase them with good reason and I need to know when you intend for me to use them.
