Results 1 to 10 of 152
Thread: Bromine Chemistry Question
    Jul 2013
    Northern Illinois
    Default Re: Bromine Chemisty Question
    Great news!!!!
    Thank you so much for all the help you have given me and others here on the forum. You are truly amazingly generous people to donate so much of your time and energy to us all. In my case: special, special thanks to Ben! Your patience is astounding. After reading SO MANY posts where people look for advice and then don't follow it, (even lie about following it), I know I would either give up or be a sarcastic SOB. Kudos, forum folk!!!
    Yes, I know borates are not a solution to algae. I am looking for water comfort. My grumpy husband, after swimming 3 times this year, complains about his hair and skin after being in the pool. Happy husband = happy life???? Ha!!! I will use the "slow" plan for adding borates -just in case. BTW, our Menard's has 31.45% MA at $1.99/gal.
    Quote Originally Posted by FormerBromineUser View Post
    Wow!
    Something else to consider: most of the chemicals that form in chlorinated pools, which cause undesired on skin, hair, or eyes are NOT broken down by 'shocking' but ARE broken down by chlorine + solar UV.
    Opening your cover on sunny days will probably have MORE effect on the water quality, than the borates will. Of course, the borates won't hurt.
    I don't think the borates are going to change his experience with hair and skin. It might, but I wouldn't count on it. Let us know.
    Skin oils get washed off even soaking in pure water. So he could complain just being in any body of water for too long. Does he complain about the feeling after being in a bathtub for as long as he would be in a pool?
    The other factor would be the active chlorine level. When previously using bromine, it is stronger than chlorine with CYA so that could have been an issue. With chlorine, so long as CYA is present, the active chlorine level is lower than that in tap water (if it's chlorinated -- not chloraminated).
    My wife is in our pool every day for around an hour for therapy exercises and she just showers after she swims and uses three shampoos with respect to swimming/chlorine. The first one is "Ultra Swim Chlorine Removal Shampoo, Moisturizing Formula" which she uses every day. This is the primary shampoo that has reducing agents to remove the chlorine bound to organics in hair. The second is "Aquia Swimmers' Shampoo and Conditioner by Barracuda" which she uses most days but not necessarily every day (it has conditioner so you use it when you would want to condition your hair and not just shampoo it). The third is very strong and powerful so is only used once a week and is "Paul Mitchell clarifying, Shampoo Three". This latter will strip your hair if you use it too often, but it is the only one that removes a slimy buildup at the nape of the neck at lowest base of hair -- probably an accumulation of suntan lotion.
    Again, a big issue is just being in water for a long time. Sure, the chlorine doesn't help, but it's not the only factor.
    Virginia
    Or you could use 72 pounds of boric acid. At DudaDiesel this is $65 for 55 pounds plus $45 for 25 pounds plus shipping for the 55 pounds so $110 plus shipping (or 3 25 pounds would be $135 with free shipping). AAA Chemical has $60 for 50 pounds so $120 for 100 pounds plus shipping. The Chemistry Store has $89.10 for 55 pounds and $27.75 for 15 pounds so that's $117 for 70 pounds plus shipping.
    Personally, I find using boric acid to be a lot easier since it's just one chemical to add. It didn't used to be as inexpensive as Borax plus acid, but these days it's a lot closer and I think a lot more convenient. Be sure to get granular and not powdered -- the powdered version tends to sit on top of the pool. The granular still dissolves very quickly and is gone with some light brushing. The effect on pH only drops it from 7.5 to around 7.2 when you add 50 ppm borates (the quantities above).
    I switched to using boric acid last year. Much more convenient and I don't have to deal with handling MA.
    Btw, I don't know how much adding borates has to do with this, but I noticed that since lowering my TA to 70-80, my pH settles at 7.5 to 7.6 with the SWCG running and doesn't rise any higher. I didn't have to add any MA all last season nor so far this season.
    The borates definitely lower the rate of pH rise because they are a pH buffer. The borates will also help reduce or eliminate scaling in SWCG cells, but that's explained by their pH buffering. They don't change the amount of acid you would need to add over time. The lower TA is what fixes that so the combination basically stabilizes your pH.
    Virginia
    Thanks for the explanation.
    Its been nice not having to mess with adding MA. Of course it was following advice on this forum that lead to finding my pool's sweet spot.
    Jul 2013
    Northern Illinois
    The hubby loved it when I added optimizer to our former water and is convinced borates will be the answer now. I don't plan on telling him what you said about borates probably not making a difference and just see what his reaction is when he next goes in. I will let you know what he says!
    And to you also, JimK, I wish now that I hadn't stocked up on MA before reading Richard's and your posts about granular boric acid. (At $1.99/G, it was hard not to... my Menard's now raised their price now to $3.57 -still a deal). I found the process of adding borax and MA to be the pits. I would have loved to avoid that!
    Btw, I only added 18 boxes of borax before running out. (I wiped out the shelves at several stores). I tested with the Lamotte strips and it seems to read between 50 and 80. I'm not sure why since I didn't add all the borax called for. I will keep an eye on it and see if my reading changes for any reason. I thought I was done reading test strips. Ugh!
    Something else to consider: most of the chemicals that form in chlorinated pools, which cause undesired (effects) on skin, hair, or eyes are NOT broken down by 'shocking' but ARE broken down by chlorine + solar UV.
    I was keeping the auto-cover closed a ton trying to warm up the water. If it ever gets sunny, I will open it up. Thanks for the info; I didn't realize that UV radiation had an effect on breaking down bad stuff. Always learning here on the forum!
    Most owner-reported pool volumes are high. Liner volumes supplied by builders and liner makers are for the OVERFLOW volume, not the actual in-pool water.
    Jul 2013
    Northern Illinois
    Good point. I thought about that too....
    When I originally figured my volume I used: 20x40 rectangle with an average 5' 8" (5.66') depth (3.2" shallow, 8.3" deep) to get around 33K.
    Then, when we filled this year, I had 4 truck loads of water brought in. One truck supposedly held 5.9K, the other 5.8K. That's almost 24K total. Then I added over a foot with my hose which I calculate added another ~6,000+G. (20x40x1=800ft3=5,948G=~6K) 24K+6K=30K That put me at a revised 30K figure.
    Do you think the corner bump-outs (see avatar) can account for that big of a difference? Am I doing something else incorrectly?
    Inset corners -- 3' 90 deg radius x 4 => 3^2 * 3.14 * 3.2 * 7.46 = 700 gallon deduct
    Steps: 1/2(4' inset * 2.8 deep) * 6 wide * 7.46 = 250 gallon add
    Shallow part of pool: 20 * 40 * 3.2 * 7.46 = 19,098 gallons add
    Deep part of pool: 20 * 20 * [(8.3 - 3.2)/2] * 7.46 = 7,610 gallons
    [Probably should be [(8.3 - 3.2)/3] -- but it depends on the shape of the slope and hopper ]
    19098 + 7610 + 250 - 700 = 26,258 total
