Thread: Help why is my pool cloudy again?????
    May 2013
    Northwest Indiana
    Default Re: Help why is my pool cloudy again?????
    You need to post your cya... It's possible your fc is too low. Please post complete test results so people here can help you more effectively. Thanks
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    BigDave's Avatar
    pH below 6.8 is one if the only "Hurry Fast! Fix it now! Issues we see. So...
    Get some Borax in there ASAP! I can't really answer about the cloud, acidic water is often clear. But...pH below 6.8 can be way below 6.8 and must be corrected.
