Thread: How long to get Borax PH increase test results?
    Default Re: How long to get Borax PH increase test results?
    Quote Originally Posted by duraleigh
    Dog,
    Download the bleachcalc in any of mwsmith2's post...you need it.
    10 lbs of baking soda will raise your pool to around 60ppm....still 20ppm lower than the recommended level....I'm saying 10 because I still suspect that test result for Alk
    I'll bet Carl's post of 1 lb was a typo.
    Put 'em both directly into the skimmer, slowly, pump running.
    Thx for the advice.
    BleachCalc won't work on my Mac.
    Katy, TX
    I'd start with 4# and see what happens. You can adjust upwards from there. Slapping 10# in there at once might not be a good idea!
    Michael
  1. Replies: 21
    Last Post: 06-05-2012, 01:12 PM
  2. Lots of borax and baking soda - No results
    By Gibgrl in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-30-2012, 08:26 AM
  3. Long term results for my SWG
    By jeffmull in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2010, 03:42 PM
  4. Borax test?
    By halefmly in forum DPD-FAS based testing
    Last Post: 08-13-2006, 10:53 AM
  5. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
