Pump or Electrical Problem
Hello - I am having trouble with my pool filter pump. Simply put, it won't turn on.
It was working just fine until a couple of days ago. Here is what I know:
- The pump spins.
- The pump makes zero noise when I push the button to turn it on.
- When I push the on button I hear a loud click from the relay module, but I don't sense any voltage on the wires leaving the module. When I test voltage on other wires that are on I am getting voltage.
- I have a Jandy Aqualink. PCB#: E0260500B; ASSY#: E0260600; Relay Module: PCB#: 3652D
I assume that something needs to be replaced, but don't really know how to determine what it is. My best guess right now is there is something wrong with the relay module. Is there anyway to confirm this?
Also, if the pump or capacitor has failed, I should still be able to detect power from the relay wires, right?
Thank you.
Zak
