Re: Pool Startup - Cyanuric Acid
Thanks. I ended up getting http://www.lesliespool.com/Home/Pool...ers/12302.html and adding ~3.75 lbs to my pool per the instructions. Their liquid was twice as expensive and the the label of the previously mentioned product was 99% cyanuric acid. I will continue to use regular 8% bleach to maintain my chlorine levels. Thanks.
