Results 1 to 10 of 11
Thread: Deck edging
    Aug 2013
    Usa
    Default Deck edging
    I have a oval above ground pool with a deck around it that meet the pool under the copin. I would like to build onto the deck some type of decking that goes above and covers the coping so that the plastic coping is not seen. Any ideas how to do this? Thanks.
    Jun 2013
    Central Florida
    Default Re: Deck edging
    Can you post some pictures? Wood deck or other? You want decking to cover the coping so it can't be seen from the deck, the pool, the house????
    Aug 2013
    Usa
    It is a wood deck. Trying to cover the plastic coping so that it look more like an inground pool. When I'm on the deck I don't want to see the plastic edging, but wood that goes over the decking. I think I should have had the deck go above the coping instead of under. Don't know if it is fixable.
    Jun 2013
    Central Florida
    I doubt that you would want some kind of step or ledge. So removing the decking and raising the frame seems about it. I suppose you could just add on top of the deck that's in place. What's the distance from the top of the deck to the top of the coping? Square/rectangular/round or oval?
    Aug 2013
    Usa
    Quote Originally Posted by nefretrameses View Post
    About 3 inches. Oval pool. Could I do a 3 inch thick board around the pool and then put a 2 by 12 deck board on top of it that goes out over the coping and then put wood edging on the end. Don't know how to attach the block so that it can support the weight log the 2 by 12.
    Jun 2013
    Central Florida
    A 2 x 12 will tolerate a fairly large distance between supporting members below it. I dont think id go more than 24 inches. You could use a 2 x 4 on edge. Its 1/2 inch too tall, but that should provide a little "wiggle room". Drill holes at an angle and secure to the existing deck with screws. Id use stainless steel or at least coated deck screws. You could look at the man made decking for the face inside the pool. It may need a new edge, but it should work like wood. Leave the new deck boards a little long over the coping temporarily installed. Take the face boards and clamp it in place so that it makes the arch you want. Mark the deck boards and cut them to the mark. There is also PVC trim boards you can get at Lowes or HD. You could use the man made decking for the whole thing too, but Id make the supports have a 16 inch spacing.
    Aug 2013
    Usa
    Any ideas to cover the plastic pool edge with wood would be appreciated. Thanks.
    I think the hesitation may be that folks are reluctant to give you an answer you're not likely to appreciate: if you want to cover that coping in a seamless fashion, you're basically going to have to remove your entire deck, add new higher supports, and the replace the deck and fence.
    I'm not a skilled carpenter myself, so I can't really tell you how best to do it. I will caution you that you probably do not want treated wood edges where the coping is now: it might be fine for a year, but after it weathers, it will provide your guests with 'thread-picked' swimsuits and butt splinters.
