Results 1 to 10 of 11
Thread: Deck edging
    Jun 2013
    Central Florida
    Default Re: Deck edging
    A 2 x 12 will tolerate a fairly large distance between supporting members below it. I dont think id go more than 24 inches. You could use a 2 x 4 on edge. Its 1/2 inch too tall, but that should provide a little "wiggle room". Drill holes at an angle and secure to the existing deck with screws. Id use stainless steel or at least coated deck screws. You could look at the man made decking for the face inside the pool. It may need a new edge, but it should work like wood. Leave the new deck boards a little long over the coping temporarily installed. Take the face boards and clamp it in place so that it makes the arch you want. Mark the deck boards and cut them to the mark. There is also PVC trim boards you can get at Lowes or HD. You could use the man made decking for the whole thing too, but Id make the supports have a 16 inch spacing.
    Aug 2013
    Usa
    Any ideas to cover the plastic pool edge with wood would be appreciated. Thanks.
    I think the hesitation may be that folks are reluctant to give you an answer you're not likely to appreciate: if you want to cover that coping in a seamless fashion, you're basically going to have to remove your entire deck, add new higher supports, and the replace the deck and fence.
    I'm not a skilled carpenter myself, so I can't really tell you how best to do it. I will caution you that you probably do not want treated wood edges where the coping is now: it might be fine for a year, but after it weathers, it will provide your guests with 'thread-picked' swimsuits and butt splinters.
    Jun 2013
    Central Florida
    I'm not sure there's a way to support a new deck board above the coping along the straight sides of the pool. I was thinking that you could place a 2 x 4 on edge over each row of screws/nails in the old deck and place a new deck on top of this that would overhang the coping. But you would need to use a 2 x 8 on edge that was notched out so that it extended over the coping and was still thick enough to support the new deck. If you used a 2 x 6, the notch would only leave a 2 1/2 inch thick portion to support the deck over the coping - this is not enough. You are looking at raising the existing deck by about 9 inches and the new deck would be higher than the coping by 5 1/2 inches. I'm not sure that would be satisfactory.
    If this is still something you want to try, I'd suggest using pressure treated for the 2 x 8's and "Trex" or similar plastic/pvc/recycled decking. You can then make a "face" that attaches to the edge of the new 2 x 8/deck to cover the edge. Your fence will appear quite a bit lower from the new deck as well. I'll still do sketches if you want. It appears to be a lot of work (and pricey). How about just painting the coping?
