Thread: How to use an Intex pump as a vacuum-EASY BREEZY WAY!
    Jul 2012
    Mexico, Missouri
    Default Re: How to use an Intex pump as a vacuum-EASY BREEZY WAY!
    I have a 1-1/4" pool vacuum hose I use to vacuum my pool with. The outside diameter of the cuffs on the ends are just the right size to fit inside the original (small) adapter for the over-the-wall skimmer.
    I remove the skimmer hose, and just "plug in" the end of the vacuum hose, after filling it with water. Hint: you can fill your vacuum hose by holding one end over the return jet to blow the air out of the hose.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jun 2013
    Texas
    Thanks. I'll try to email it over here.
