Results 1 to 10 of 14
Thread: winterizing
    Aug 2013
    Pennsylvania
    Default winterizing
    I am getting ready to winterize my pool here in Pennsylvania. This past spring when I opened my pool it was thick with algae. It is always messy but this year was the worst. I had to replace a lot of parts on my pool this year (mostly just wore out since it is 15 years old) but I would love to have a smoother opening this year. Any suggestions on winterizing chemicals? Thanks
    Aug 2013
    Pennsylvania
    Default Re: winterizing
    26,000 IGP vinyl with mesh cover. close in September and open in May.
    I understand the BBB Bleach for chlorine, borax for ph, baking soda is for alkalinity? My alkalinity only gets low once or twice a year. Is CYA stabilizer? I usually try to keep mine within the recommendations on the taylor testing kit. Usually only need that a couple of times a year too. Sorry for all the questions but this is all interesting and could potentially save me hundreds of dollars a year.
    IGP 26k gal 3-8ft vinyl rectangle mesh winter cover
    Virginia
    Quote Originally Posted by apearso View Post
    I have a similar pool, 20k IG, and best thing I did was switch from a mesh cover to a solid cover (actually, I cover the mesh safety cover with a tarp style solid cover; much cheaper than outright replacing the safety cover).
    With the mesh cover I was told not to close the pool until the water stayed below 60 and open it before it reached 60. In SE VA where I live, this means waiting until late Nov/ early Dec to close and open by the beginning of March. This meant maintaining the pool several months that it wasn't in use (too cold!). If I stuck to this schedule usually, but not always, I wouldn't have a green pool in the spring, but the bottom was covered with fine dirt and took several vacuumings to clean, it was a PIA.
    Since using the solid cover, I've not had a green pool in the spring and there's far less dirt to vacuum; opening is MUCH easier. I can close it when we stop using it, usually early Oct, and open it when it's warm enough, usually early May. A few years ago when I removed the cover in early May I discovered the liner had detached and come down along one wall and the foam behind the liner had bunched up all around the pool (a couple of bad nor'easters were probably to blame). The earliest anyone could come to repair it was June 8th, so I covered it back up and hoped for the best. To my happy surprise when we pulled the cover off in June the water was still clear! Btw, I hadn't added anything to the pool other than the usual winter chems the fall before.
    So my recommendation? Get a solid cover!
    22'x40' Grecian Lazy L 20K gal IG vinyl pool; Aqua Rite SWCG T15 cell; Hayward Pro Grid 6020 DE filter; Hayward Superpump 1hp pump; 12 hrs; Taylor K-2006; city; PF:6
    May 2011
    Southeast Massachusetts
    I've got an above ground so my situation is different but some things are universal I would guess.
    I have a solid cover as well. I've been using the BBB method since I bought the house with the pool, about three years now. The first year I opened it we had an algae bloom that lasted for 2 or 3 weeks. Since then we've had smooth sailing.
    I keep it simple. I add a bottle of polyquat algaecide and 3 or 4 gallons of bleach. Put the air pillow on then the winter cover. I check the water clarity every 2 or 3 weeks until the surface is frozen and then again in the spring. I open early...late April to Mid May and I close late...usually 2nd week in October. That's it. Sometimes I wonder..."what am I missing that those $$ winterizer kits have that I don't"...but the proof is in the pudding.
    15,000 Gallon AG -24' round -- Vinyl Liner -- 1 HP Hayward Power Flow LX -- Sand Filter -- PF=5.5
    Virginia
    Quote Originally Posted by robbym70 View Post
    I've been using a closing kit since 2004 that worked well. Last year I finally took a closer look to see what was in it; polyquat, stain inhibitor, phosphate remover, and borax. I've learned here that I don't need the phosphate remover, I already have polyquat and stain inhibitor on hand, and I already keep borates in the pool, so this year I'll forgo the kit and simplify the closing process.
    Gotta love this forum!
