Results 11 to 14 of 14
Thread: winterizing
    Default Re: winterizing
    With a mesh cover, you need to maintain the water under the cover, all winter long. Pouring bleach through is an excellent way to do so -- but use a hose to rinse off the cover afterwards.
    Aug 2013
    Pennsylvania
    thanks, i'm going to try it. This past spring was a pretty rough opening so hoping for better this time.
    IGP 26k gal 3-8ft vinyl rectangle mesh winter cover
    Quote Originally Posted by PoolDoc View Post
    Happily, I've never had to do that with my mesh safety cover. Here in the NE (and Pennsylvania is like NJ, maybe colder), it's usually so much colder that it isn't necessary. I find if I open in April, after the ice has melted, I have to spend far less time and use less chems than I do if I open in May, when I'm more likely to have algae.
