Results 1 to 10 of 25
Thread: Thank you! My algae is almost gone!
Threaded View
  1. #14
    May 2013
    Concord,ca
    Default Re: Thank you! My algae is almost gone!
    Ben, after checking the k 2006 the cya is at 30 ( cant read below that) following are my findings
    ch1.0
    ph 8.0
    ta 100
    <30 cya
    Unfortunately I went to the pool calculator and did what it said by adding 24 oz muratic, 20 oz liquid conditioner and 2 Gallons chlorine, but I will go to WM and get the 15 gallons this morning
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
