Results 1 to 10 of 25
Thread: Thank you! My algae is almost gone!
    Default Re: Thank you! My algae is almost gone!
    You will need stabilizer, but while dealing with an algae outbreak is not the best time to add it. No real harm done, however.
    May 2013
    Concord,ca
    thanks for getting back Ben, after adding 2 gallons CH, I'm seeing 2.3 on the CH..... 7.4 on ph .....100 alky..I added 1 more gallon of CH. My cya still read ,<30 no prob. CH is coming up, I'm watching it....No fun though....I swept the pool for 2 hours yesterday and got IN the pool and while there swept for 3 more. Question .....when you sweep is it necessary to get ALL the light green off before filtration takes over? Found out while being in the pool my Barracuda MX8 for the second time quit running...gears must be shot again I don't know what other sweeps might be better or maybe just do it by hand. Thanks again...Dave
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
