The cya test is tricky to read correctly. You want bright, indirect light. So ideally stand in sunlight with your back to the sun (your shadow directly in front of you) and view the dot in the comparator by holding it at your waist. You can also pour the sample back into the bottle and retest a second or third time to verify your results.
