No problem. You also want to make sure you leave the pool uncovered as much as possible when the sun is on it... Sunlight and outgassing will help keep cc in check.
-Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
@Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
Read the Best Guess Chlorine Chart in my signature below for more about the connection between CYA levels and needed chlorine levels.
