Results 1 to 10 of 15
Thread: 27K gallon pool with slippery sides
    Jul 2013
    NJ
    Default 27K gallon pool with slippery sides
    First I'm a new pool owner. I had the same slipperiness problem now I have spots of darker algae I guess. Can I do the same? I have a 27,000 IGL pool.
    Default Re: Slippery pool surface?
    We often recommend bleach, because it tends not to mess other things up, regardless of pool chemistry. One exception: if your pool has copper in it, from algaecides, an ionizer, or a corroding heater, you have to avoid high levels of chlorine, regardless of type.
    Later, when we know more about a user's pool, we may recommend other forms of chlorine.
    On your pool, you can safely add 2 gallons of PLAIN 8.25% household bleach each evening. Get an OTO / phenol red kit (yellow / red drops) and report results. But keep on with the bleach, till you know more.
    Order a Taylor K2006 test kit from Amazon (link in my blue signature block); you WILL need it. But get the OTO kit locally; you need it now. Read the Best Guess page in my signature too.
    But . . . add the 2 gallons each evening -- that will keep you out of trouble, till you know more.
    Jul 2013
    NJ
    I received the taylor kit got it from amazon from your link. I tested the FC was 6 ppm PH was 7.8. I have a SWCG the pool is a little cloudy not to bad but still slippery
    But, what as the CYA level?
    That is critical -- read the Best Guess page, linked above in my blue signature block. It explains why it's so important to know your CYA level, AND what to do, when you know it.
    Meanwhile, use bleach to raise your chlorine level to 10 ppm or a little higher. (Once you know your CYA level, we'll have a better idea.) And, use either muriatic acid or pH Minus (granular sodium bisulfate) to lower your pH to 7.4 - 7.6.
    BRUSH your pool, once you get the chlorine up, and the pH down.
    Jul 2013
    NJ
    CYA is 10
    Really? Are you 'guesstimating' that? (There's no marking for "10" on the K2006).
    If that is so, you need to be using dichlor to chlorinate. The fact that there WAS 6 ppm FC when you tested, doesn't mean that it won't be ZERO an hour later, if the sun comes out!
    The SS recipe page (link in my blue signature block) will cover much of the info you need.
    Jul 2013
    NJ
    No I took a trip to my local pool guy. Fc is now 4.8 ph is 8.0 cya is 10.
    Ok. Then we can toss those results right out. We've encountered too many cases of completely bogus results to have any trust in those results.
    Please test with the K2006 -- FC, CC, pH, & CYA at a minimum -- and report THOSE results.
    Jul 2013
    NJ
    Fc 4
    ph 7.4
    cya 40
    Quote Originally Posted by southjerseypool View Post
    . . . local pool guy. Fc is now 4.8 ph is 8.0 cya is 10.
    Fc 4 ph 7.4 cya 40
    And . . . that is why we NEVER trust pool store (or pool guy) results! Getting the CYA wrong by 400% is not 'close'!
    OK. 5K gallon pool (15' x 3.8' water depth); PF=24. 1 gallon of PLAIN 8.25% bleach adds about 17 ppm of chlorine to your pool. (24*0.7 lbs /gal = ~17)
    1. Start dosing each EVENING with 1 full gallon of plain bleach.
    2. The following evening, test with OTO. If the result is clear to light yellow, add 1 more gallon. If DARK yellow, 1/2 gallon. If ORANGE, skip that dose.
    3. Continue dosing in this manner for 2 days AFTER there's no trace of slipperiness or algae remaining.
    4. Starting the 2nd night, BRUSH the pool completely every 2 days.
    5. When you reach your final bleach dose (per #3 above), test 1 hour after dosing using the FAS DPD test. Test for BOTH FC and CC. Test AGAIN the following AM, before full sun hits the pool. Report those results here.
