Results 1 to 10 of 12
Thread: Vacuuming
    IL.
    Default Vacuuming
    For manual vacuuming, Just curious about a few things.
    On average, how often do you vacuum, assuming normal operation and not trying to clean up after a problem?
    When you do vacuum, do you always vacuum to waste?
    Indiana.
    Default Re: Vacuuming
    Usually weekly. Sometimes I spot clean to get grass or leaves out after a storm.
    I seldom vacuum to waste. Backwashing uses less water, and I'm on a well that doesn't have great water for a pool.
    docsobeck is offline PF Supporter Thread Analyst docsobeck 0
    i've been a pool owner for almost nine years now, and the next time i vacuum to waste will be the first.
    Downingtown, PA
    I vacuum once every two weeks. I usually use the leaf net to grab a lot of stuff off the bottom since it all settles in one of two spots - deep end around drains and nearby the stairs, off to the side of the returns. I will brush towards the drain weekly or bi-weekly as well. (I have plaster so I don't have to be worried about ripping a liner by "skimming" the bottom.) Never vacuumed to waste but then again, I generally clean the pool very well before opening or vacuuming. I have not backwashed yet this season -- been open over a month already.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    Philly Burbs
    I dont understand how you vacuum to waste. Wouldn't you use too much water? By the time I got done I would probably be almost below the skimmer line unless I'm missing something here.
    Downingtown, PA
    You only want to vacuum to waste if you are cleaning some nasty stuff, like a layer a couple inches deep worth of leaves and gunk off the bottom. You would not want to do routine vacuuming to waste because of the water loss.
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    A pretty large number of us use suction side cleaners without strainers. Even so, My filter hasn't needed backwashing for over two months. I think vaccuuming to waste is helpful for short term problems like major algae clean up or plant debris on the bottom. If you don't have that kind of problem then you don't need to vaccuum to waste.
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Houston.
    My Polaris 280 runs daily for 2.5 hours. I use the sand and silt bags so it picks up tons of dust. I also rotate between two bags to allow easier cleaning of a dry bag versus trying to get wet sand out of a wet bag.
    Anyway, with running my 280, my floor bottom looks clean, so I'm never vacuuming. Should I be? My builder said with the cleaner, I'll probably never need to vacuum. He told me incorrect information before, so should I be vacuuming for some reason?
    In fact, I like the idea that the 280 puts the dirt in the bag that I then empty in the trash versus the vacuum that would put the dirt in the filter.
    Thanks,
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
