Results 1 to 10 of 16
Thread: Using variable speed pool pump with SWG
    La Quinta, CA
    Default Using variable speed pool pump with SWG
    I am considering converting to a variable speed pump. The vendor says I will save a lot of money my electric bill. They want to program the pump to run 7 hours a day at 1750 rpm and 3 hours a day at 2750 rpm. Now the question....is this enough time at the 2750 speed for my Intelichlor IC-40 SWG to make enough chlorine for my pool? I currently have a one speed pump that runs 8 hours a day at 3450 rpm and does the job. I am concerned that 3 hours a day at the 2750 speed and 7 hours at the 1750 setting will not produce enough chlorine for my 40,000 gallon pool. Comments please. And thank you in advance.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Using variable speed pool pump with SWG
    Pump speed has almost nothing to do with chlorine production as long as the minimum flow rate requirements are met. If 8 hours is enough for your old pump, 8 hours should be enough for your new pump. But the vendor's schedule is a little overkill in my book. 1-2 hours at 2500 and 7-6 hours at 1000 RPM should be enough run time (8 hour total). Most VS pumps have peak efficiency around 1000 RPM so I would target most of the run time around that.
    Mark
    La Quinta, CA
    mas985.....thanks for the info.
    La Quinta, CA
    Currently running the variable speed pump at 7 hours at 1750 and 3 hours at 2750 and the IC 40 is making plenty of chlorine. I am considering cutting back to 7 hours at 1000rpm and 2 hours at 2500 rpm. I live in the SoCal desert where right now the highs are in the mid 90s which eats up the chlorine. Any comments?
    mas985's Avatar
    Pleasanton, CA
    Sounds reasonable. You may find that you can cut back even further.
    Mark
    Interesting. Not familiar with VS pumps (only 2spd pumps). My SWCG can actually be wired to control the pump and the pump speeds, but I keep it simple, personally.
    La Quinta, CA
    Update: I am still running my VS Pentair pump 10 hours a day....7 hours at 1750rpm and 3 hours at 2750rpm. My Intelchlor 40 SWG is pumping out plenty of chlorine running at 60%. I am considering cutting back on the pump runtime to save even more energy. With the VS pump I am now down about 40% from the energy useage of the single speed pump I used to have. Comments?
    mas985's Avatar
    Pleasanton, CA
    Why so high on the RPM levels? I thought you were going to reduce those.
    I would target 1000 RPM for the lower speed and 2000 RPM for the higher speed and only for 1-2 hours.
    Mark
    La Quinta, CA
    Mas985 said: Why so high on the RPM levels?...................The rpm levels were programmed by the installer...he works for a very reputable long-established pool company and seems to know his business. Since I had no experience with VS pumps I went along with his suggestion of 7 hours at low rpms and 3 hours of faster rpms. I cut back to 6 hours of low rpm a few days ago and will be monitoring the water quality. My IC-40 chlorine generator is now set at 60% and still producing plenty. I started with it at 100%. As I mentioned I will be keeping a close eye on the pool. I also use a Pool Shark and it works well at the 2750 rpm setting....much slower at the 1750 rpm setting. My pool is a large one (48 feet, 40K gallons) so the Pool Shark has a lot of pebble tec to clean and I'm not sure it can get the job done at the 2000 rpm setting.
    La Quinta, CA
    Got my first electric bill since the VS pump was installed a month ago. Useage down almost 50% from a year ago...same number of days in billing cycle, WX conditions also about the same. Amazing.
