Sounds reasonable. You may find that you can cut back even further.
Mark
Interesting. Not familiar with VS pumps (only 2spd pumps). My SWCG can actually be wired to control the pump and the pump speeds, but I keep it simple, personally.
Update: I am still running my VS Pentair pump 10 hours a day....7 hours at 1750rpm and 3 hours at 2750rpm. My Intelchlor 40 SWG is pumping out plenty of chlorine running at 60%. I am considering cutting back on the pump runtime to save even more energy. With the VS pump I am now down about 40% from the energy useage of the single speed pump I used to have. Comments?
Why so high on the RPM levels? I thought you were going to reduce those.
I would target 1000 RPM for the lower speed and 2000 RPM for the higher speed and only for 1-2 hours.
Mark
Mas985 said: Why so high on the RPM levels?...................The rpm levels were programmed by the installer...he works for a very reputable long-established pool company and seems to know his business. Since I had no experience with VS pumps I went along with his suggestion of 7 hours at low rpms and 3 hours of faster rpms. I cut back to 6 hours of low rpm a few days ago and will be monitoring the water quality. My IC-40 chlorine generator is now set at 60% and still producing plenty. I started with it at 100%. As I mentioned I will be keeping a close eye on the pool. I also use a Pool Shark and it works well at the 2750 rpm setting....much slower at the 1750 rpm setting. My pool is a large one (48 feet, 40K gallons) so the Pool Shark has a lot of pebble tec to clean and I'm not sure it can get the job done at the 2000 rpm setting.
Got my first electric bill since the VS pump was installed a month ago. Useage down almost 50% from a year ago...same number of days in billing cycle, WX conditions also about the same. Amazing.
I don't understand why some think variable speed motors are not worth the investment.
IC 40 still producing plenty of chlorine so I backed it down today to 40% output. Correction: In the above post I said my electric bill was down 50% from a year ago which I attributed to the new VS pump....actually it is down 35%...which I think is still pretty good.
