I stated it has an effect on PH. As for adding acid, I don't expect it to be much, backed up by this info from Ben in his TEKTATs-Originally Posted by gregugadawg
"Probably the greatest chemical destruction I see at the large commercial pools results from the fumes of muriatic acid used to control pH. I've literally seen over $100,000 of damage at just one pool. Much of this comes from attempting to follow the dictates of the pool industry TEKTAT: "if you use bleach, you must use lots of acid."
BS! (Barnyard Slush)
Just to keep it short, I'll invite anyone who wants to, come watch me manage a 300,000 gallon pool this summer with less than 5 gallons of acid . . . while using hundreds of gallons of bleach!"
Huh? I've had the partial drain happen over and over with stabilized chlorine sources, but never with bleach. Heck, it's a little bit of chlorine gas, a little bit of sodium hydroxide and mostly water.it has a high tds and increases your tds value fast which can cause you to have to partially drain the pool.
If maintains a proper residual this doesn't seem to be the case. We had a large crowd on Memorial day. I had a 4 ppm FC pre-party. After many hours by many people in the pool, it was still 2 ppm.Also unless you have a liquid feed system you don't have a constant supply of chlorine in the water. So in the instance of a large party you could easily show a chlorine reading of 0 halfway through the party with no safe way to get chlorine in the water, while using a feed system would allow you to constantly have a residual in the water.
In my opinion these cons are kind of weak, and you could nit pick any chlorine source like this. I just want to hit the major highlights.
Sure they will, for about double the cost of new ones from the grocery storeI do agree with the rest but I feel like she asked for un-biased advice which would need to include more cons for liquid instead of having to throw away the bottles. Plus pool stores will re-fill your bottles for you anyways. Everything in life has both pros and cons, so be sure to include both.![]()
