Thread: Using an intex pool cover
    Jul 2013
    CA
    Default Re: Using an intex pool cover
    I tried that with one of my Floaties which was about 5" high.
    It took up too much of the slack in the cover and it wouldnt go all the way to the edge of the pool frame to tie it off.
    Quote Originally Posted by Blackmagic View Post
    Then you need to drain off enough water so you can tie it off. If it's an Intex inflatable donut and your water will freeze, you are probably making a mistake.
    BTW, inner tubes make good pillows too.
