Results 1 to 10 of 11
Thread: Any problem with pool shock that sits on bottom of a plaster pool?
    Jun 2013
    Central Florida
    Default Re: Any problem with pool shock that sits on bottom of a plaster pool?
    After you get the stuff on the bottom dissolved, recheck you CH. I've read how you can minimize the amount of calcium added to a pool but mixing cal-hypo in a bucket of pool water and pouring it into the pool until you start getting some slurry. Mix it again and pour again until you get slurry, then toss the rest. I guess the calcium dissolves slower than the "hypo". Maybe that's what's on the bottom of your pool - or other unknown stuff like CarlD describes in "cheap" products.
    Tom, I just gave you what I think are reasonable alternatives to explain your problem. If you and the pool store are getting similar results then you are probably running the test correctly. You can always put a handful of the cal hypo in a couple of gallons of water and see if you get really, really high results when you run the test. If you still get "zero" you're doing something wrong or have bad reagents.
    BigDave's Avatar
    50 lbs in 22,000 gallons should raise the calcium by more than 100 - this should be visible on the test.
    Ben describes a method of dosing cal-Hypo designed to prevent buildup for pools with sand filters. Dosing cal-hypo through the skimmer and letting it dissolve on the sand bed encourages the calcium to precipitate out onto the filter. This acts as a filter aid and can help keep some of the calcium out of solution. I can anecdotally confirm this as I used this method for the last half of last season; I didn't measure an increase in calcium (only tested twice), I did find fine white material (finer than sand) on backwash. Warning! cal-hypo must never be put in the skimmer if there's any chance that any stabilized chlorine could be in the circulation system - this can cause an explosion.
