Thread: How do I check for a list of my posts?
    Jun 2013
    Central Florida
    Default Re: How do I check for a list of my posts?
    You are listed as a "general user". I believe that indicates that the Moderator "Pool Doc" has not upgraded your status yet. He has been ill. Also, f you did not provide sufficient info for him to verify that you are not a spammer, he may not have done so.
    I'd post a new message asking for an update on your membership status. That should prompt some kind of response. Subscribing will give you these rights automatically and supports the forum.
    Jun 2013
    Atlanta Georgia
    Thanks for the info.
    Where should I post that message?
    Jun 2013
    Central Florida
    Forum Q&A I think.
    Largo, Florida
    In the meantime, this link should do what you're after: http://www.poolforum.com/pf2/search....st&showposts=1 Unless you also don't have access to the search function.
