Results 1 to 8 of 8
Thread: How many ppl BBB and winterize pool?
    Oct 2013
    Houston, TX
    Default Re: How many ppl BBB and winterize pool?
    I think I was told to run the pump about 8-12hrs as a rule of thumb or calculate how long it would have to run based on your water amount and pump size. How much shorter do you run pump in the summer than in the off season?
    I'm not sure I understand why the pool would cost much higher in the summer than all year. Is it because of the sun and the chlorine?
    Less sunlight => lower rate of chlorine loss
    Lower temperatures => lower levels of chlorine required to maintain an algae free pool
    Fewer swimmers => less 'pool goo' to oxidize.
    Jun 2013
    Central Florida
    8 or 9 in summer = the water is not too cold to swim in. As the sun receeds it drops to 6 or so and by Nov. to Mar. 4 or so.
