Re: Green pool
Things are looking up. The pool is no longer emerald green but much a much lighter shade. It is still cloudy. This AM the values were: CYA 50, FC 8.5, CC1.0, TA 130 and Ph 7.5. I have had to add some more water to the pool because of the backwashing.
Shall I still put in the 4 gal. of chlorine this evening? I have some Super Shock (Kem Tek) Trichloro - s- triazinetrione that I had before I joined BBB. Can I use any of that?
When using the pool calculator, how can I tweek it to tell me shock levels of chlorine and not just maintenance levels?
Thank you for your help.
24K gal, IG, fiberglass,Hayward DE 4820, GPM96, 1 HP 2 speed Whisperflo pump, Pool built over 30 years ago (plaster) Resurfaced 7or8 years ago with fiberglass, Polaris 180
