Results 1 to 10 of 15
Thread: Homeade Pool Steps?
    Default
    I've never had any problems with the dog and the vinyl liner. My dog is a Chesapeake Bay Retriever (about 74 pounds) and she swims in it more than anyone else!
    If you want the dog to use the pool, make sure you get one with built-in steps - like I said, my dog can't get out by herself. Anything I get now will either be A. Expensive or B. Unsightly or awkward. I've taught her to rest while standing in the shallow end, but if she somehow got into the pool without us around, there's a serious chance she would drown. She will swim for hours upon hours - which, as you can imagine, leads to exhaustion.
    I also bought the Skamper Ramp - it was way too flimsy for my dog, even though I bought the extension for larger dogs. It would probably work with the smaller dogs, though. I keep it in the pool to save small animals that fall in the pool. I'm pretty sure it works because before having the Skamper Ramp, I used to find dead squirrels, rabbits, snakes, etc. fairly often, but none since I got it. It is definitely NOT for medium to larger dogs - maybe in an emergency.
    Any other thoughts on makeshift steps or ramps for the dogs?
    kaybinster Guest
    Default
    I have two siberian huskies that love to go swimming in the pool. They have never hurt the liner, but we have built in steps that they use with no problem. I had a tech come work on my hidden fence (keeps the dogs on the property) and he brought his lab with him. That dog was amazing. He would jump about four feet in the air and dive into the pool. What was amazing was he did not use the steps to get out, he knew how to climb the ladder! Now that is some smart dog.
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Default
    Here's a basic drawing of the step extension I was thinking about.
    Could be built flat or possibly at an angle with cleats on it.
    Notched pieces go over steps and can be held on with large zip ties, then the platform and bracing attached to those.
    Should give you something to work from.
    http://i48.photobucket.com/albums/f2...cs/Dogstep.jpg
    Hoskins, Nebraska
    Default another alternative
    My steps from Dunnrite.com were under $300 including freight charges. I love them. That is still a lot of money, though.
    A cheaper alternative that just might work is a plastic step mounting block for getting on horses. We actually have a two step one that we use to get up into our dressing room part of our horsetrailer. They come in different heights. Ours is open in the back so you could put a sand bag in it. Check with your local tractor supply stores - such as Bomgaars or TSC- or an online dealer is Valley Vet Supply. I paid $15 for mine on sale- reg. price would be around $30 or so. Just a thought.
    Sincerely,
    Donya (huskerfan)
    Default Re: Homeade Pool Steps?
    I also have a IG vinyl pool w/o steps. I am considering building my own using kingstarboard or something like it. It works as easy as plywood but is a plastic. Still need to run costs, will keep you posted.
