Results 1 to 10 of 25
Thread: Closing with "pink slime and white water mold"
    Oct 2013
    Alabama
    Default Re: Closing with "pink slime and white water mold"
    Oh my goodness!! Took the cover off - green swamp - added (5) 121 oz 8.25% Clorox two hours ago - just tested and showed 1.5ppm!!!!! Adding 4 more now. Can this really be happening?? Been scooping out chunks of green slime for 2 hours - using kneehigh hose in the skimmer - getting clogged every 10 minutes - rinsing and replacing. I'll have to take the hose off skimmer for the night - will my filter blow up???
    25K vinyl in-ground pool with mesh cover; PF=5
    Gotta get that junk out of the pool.
    Oct 2013
    Alabama
    Tested this morning and found "0" CYA - it was 45 a few days ago. Is that possible? Expected the sand filter to have way high pressure this morning, but it didn't go up - could I have a filter problem? When I turn off the pump water rushes back into the pumps skimmer - it loses prime and I have to add water to get it started again. Thanks for your advice!!!
    MASSIVE amounts of algae have been known to consume CYA and leave (I think) ammonia. If the filter pressure didn't go it, it's filtering--but you may have a leak in your plumping. It should be self-priming.
    Oct 2013
    Alabama
    Thank you Carl!
    Oct 2013
    Alabama
    Think we should rename the thread NOT closing with pink slime/wwm! To date have used 41 bottles (121oz/8.25%) Clorox. Water is finally starting to clear - can almost see bottom of deep end. Have brushed every day. I'm still trying to maintain 15ppm chlorine, but with my CYA dropping to 0, will this hurt the vinyl liner? Do I need to raise the CYA now or wait till spring? Does the mesh cover let in enough sunlight to matter?
    Thank you for encouraging me to go ahead and clean this mess up! I appreciate your help! Never seen anything like it!
    (41) 121oz bottles of 8.25% would be about 130 ppm on your pool -- that is definitely in the range of normal consumption once the pool goes swampy.
    1. If your pool is covered, don't add CYA yet. If your pool is uncovered, I'd recommend installing the mesh cover, but leaving the corners accessible, if you can do this. It's much easier to clean up an algae-only swamp covered, than it is uncovered. When you're ready to vacuum, you can just unhook and flip back one side.
    2. Have you been testing CC levels? If not, you should. It's possible your CYA has been converted in part to ammonia. If so, that consumes huge quantities of chlorine, during cleanup.
    3. I'm sorry I haven't chimed in sooner, but I was waiting to get more definitive results on using phosphate removers in conjunction with winterization. Keeping your phosphate levels below 125 ppb during the pool season can be very difficult, since phosphates can enter the pool from multiple sources -- my own local potable water has ~2ppm or 2000 ppb phosphates! But during winter, you are NOT constantly adding phosphates, so it may be practical for you to drop your phosphate level < 125 ppb, and then be able to keep it there till spring without any further effort.
    A pool with very low phosphates is not algae-proof, but it is quite algae resistant, and *should* be easier to maintain. Very likely, you can achieve that for less than $100. If you're interested, let me know. But keep in mind, I have not fully tested this method myself yet.
