Results 1 to 10 of 22
Thread: How long does the pump really need to run?
    mas985's Avatar
    Pleasanton, CA
    Default Re: How long does the pump really need to run?
    According to this web page collides are generally smaller than 1 um.This document also confirms that particles > 2 um will settle out in a few minutes but anything less than that will remain suspended indefinitely. At best, DE filter can only filter down to 5 um so any particles that are actually suspended in water, will not be filtered out anyway.
    Mark
    Anonymous [GDPR] European in the UK Guest
    Yes Mark, I agree and I said if the filtration was good enough. I don't want to get into the area of colloids yet but the point was more that continuous running of the filtration but at a slower rate will improve the the water quality by removing more suspended solids because they are suspended and so can be skimmed and filtered and not just sinking to the bottom once the water has calmed. I have vaccuumed too many pools only to see small clouds created by dirt if you move too quickly or make sudden moves. Running the sysytem continuously has removed that problem. That said, I wonder if removing too much from the water would cause a greater loss of chlorine to photodegredation as the suspended matter may shield chlorine from the sun's UV in the same way as bacteria and algae can be shielded from chlorine as stated in your second link.
    It is a fact that DE can remove Ocyst of Gardia and Crypto providing the grids are intact but DE is just a mechanical filter to go to the next level we need adsorption to draw particles to the surface of the filter media.
    As you have a large cartridge filter and a good sized 2 speed pump, I would be interested in your flow rate and system pressure at normal running conditions if you wouldn't mind passing on that information please?
    Regards
    John
    mas985's Avatar
    Pleasanton, CA
    On high speed without solar, flow rate is around 68 GPM and with solar around 58 GPM. On low speed, flow rate is half of 68 GPM or about 34 GPM.
    Mark
    Thanks Mark, What sort of pressure shows on the gauge at those flow rates? I usually fit sand filters but have a customer who specifically needs a cartridge filter and to get my system to run well the system pressure doesn't want to be too high.
    Regards
    John
    mas985's Avatar
    Pleasanton, CA
    High speed filter pressure is about 10 PSI without solar and 14 PSI with solar.
    But I don't understand what you are trying to say here:
    Cartridge and DE filters have about the same head loss independent of filter size. Only sand filters, because of the small area, have a head loss dependency on size.
    Also when sizing a filter, you really should use the APSP-15 specs and don't worry too much about pressure. APSP-15 specifications use a rate of 0.375 GPM/sqft for cartridge filters.
    Mark
    Happy new year Mark and thanks for the update. Yes with sand filters they only present a small surface area ( pi x r2 of the filter size) as the depth of the bed isn't considered for some reason so I would have expected the pressure to be lower with the large surface area of a pleated cartridge or DE grids. You say the headloss is about the same regardless of filter size, therefore they are very poor performers hydraulically speaking which doesn't surprise me as the pool industry designers are pretty lazy/useless/untrained?
    Helpful to know though thanks, On your slow speed I would have expected the headloss to drop quite a lot especially as your filter is quite big.
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by Teapot View Post
    You say the headloss is about the same regardless of filter size, therefore they are very poor performers hydraulically speaking which doesn't surprise me as the pool industry designers are pretty lazy/useless/untrained?.
    Actually it means just the opposite. Cartridge and DE filters have the lowest head loss so are are very good performers hydraulically. The head loss doesn't change with size because even the smallest size is "large". What causes the head loss in these types of filters is just the internal fittings and for DE, the backwash valve adds a lot of head loss but the media does not add much to the head loss. I can take the cartridges out of my filter and the pressure does not change which means they don't add any head loss. Only the internal plumbing fittings add head loss which is why it is so low. However, for sand filters, the sand area is quite small and that does have an impact on head loss but only for filters smaller than about 5 sq-ft.
    Here is a table with several different types of filters and filter sizes (sand only). For a given filter line with cartridge and DE, the head loss does not change with size but as you can see, the cartridge has the lowest head loss and by quite a bit of margin.
    Also, I didn't post the low speed pressure because it doesn't actually read a pressure. But theoretically, it is about 2 PSI.
    Mark
