Results 1 to 10 of 10
Thread: Sealing a leaking return port flange on gunite pool
    Nov 2013
    us
    Default Sealing a leaking return port flange on gunite pool
    In trying to winterize this year we find that we have 2 return ports that are leaking between the return port flange and the pool wall.
    What the best product to seal this?
    I've considered:
    putty-like epoxy
    polyurethane caulk
    silicone
    silicone glue
    Tips appreciated
    Nov 2013
    us
    Default Re: Sealing a leaking return port flange on gunite pool
    I'm hoping to try one of these this weekend, so any tips would be appreciated!
    I have used the putty like epoxy on leaking spa fittings, even leaking or with some moisture present, so since the pool walls will still contain some moisture, the epoxy putty might be my first choice, but I'm open to new ideas!
    Nitrile rubber would be my first choice -- info here:
    http://www.kelleytech.com/olympic/ol...view.asp?ID=29
    Epoxy putty may last, but my experience has been that it tends to develop gaps after a few years.
    Silicone rubber is a mess; don't go there.
    Or, you can choose to fix it right, by chiseling it out, and using something like Waterplug. Do **NOT** use some of the low grade cement patches that Lowes and Home Depot sometimes carry!
    Here's my Amazon store page: http://astore.amazon.com/poolbooks?node=43
    but you should use the pictures as a guide, and check around at other pool stores -- Amazon is not carrying those products directly so delivery and prices may be better elsewhere.
    Nov 2013
    us
    Not sure how we might use the hydraulic cement.
    Looking into the return ports from the pool side, it looks like the pvc may have originally glued into them. If so, I guess the glue has partly failed.
    If we broke up the current return port flange, and chiseled it out.....not sure how we'd ever get back to a good glue joint between a new flange and the old pvc.
    You'll have to post pictures (or email them to [email protected]). Most return inlets that I've seen consist of a pipe stubbed through the gunite, with a female fitting on the end. Then, the return eyeball fitting is screwed into the pipe, after the pool is complete. Any flange would be under the fitting, and retained by it. If you have a different arrangement, appropriate repairs may be different.
    Nov 2013
    us
    The pvc is stubbed through the concrete wall. The return port flanges are slipped over the pvc with a typical glue connection. It would seem that the failure is at this glue connection, as under air pressure when winterizing, with the outlet plugged, air leaks between the flange and the wall.
    The return flange port, once installed, does have female threads, but that is just to accept an eyeball, or for plugging in the winter. Those threads, in this case, don't pertain to how it's installed.
    So given this kind of setup, any idea as to how one would repair a leak between the pvc and the return flange - internally? Still use the hydrallic cement?
