Results 1 to 10 of 10
Thread: Sealing a leaking return port flange on gunite pool
    Default Re: Sealing a leaking return port flange on gunite pool
    Nitrile rubber would be my first choice -- info here:
    http://www.kelleytech.com/olympic/ol...view.asp?ID=29
    Epoxy putty may last, but my experience has been that it tends to develop gaps after a few years.
    Silicone rubber is a mess; don't go there.
    Or, you can choose to fix it right, by chiseling it out, and using something like Waterplug. Do **NOT** use some of the low grade cement patches that Lowes and Home Depot sometimes carry!
    Here's my Amazon store page: http://astore.amazon.com/poolbooks?node=43
    but you should use the pictures as a guide, and check around at other pool stores -- Amazon is not carrying those products directly so delivery and prices may be better elsewhere.
    Nov 2013
    us
    Not sure how we might use the hydraulic cement.
    Looking into the return ports from the pool side, it looks like the pvc may have originally glued into them. If so, I guess the glue has partly failed.
    If we broke up the current return port flange, and chiseled it out.....not sure how we'd ever get back to a good glue joint between a new flange and the old pvc.
    You'll have to post pictures (or email them to [email protected]). Most return inlets that I've seen consist of a pipe stubbed through the gunite, with a female fitting on the end. Then, the return eyeball fitting is screwed into the pipe, after the pool is complete. Any flange would be under the fitting, and retained by it. If you have a different arrangement, appropriate repairs may be different.
    Nov 2013
    us
    The pvc is stubbed through the concrete wall. The return port flanges are slipped over the pvc with a typical glue connection. It would seem that the failure is at this glue connection, as under air pressure when winterizing, with the outlet plugged, air leaks between the flange and the wall.
    The return flange port, once installed, does have female threads, but that is just to accept an eyeball, or for plugging in the winter. Those threads, in this case, don't pertain to how it's installed.
    So given this kind of setup, any idea as to how one would repair a leak between the pvc and the return flange - internally? Still use the hydrallic cement?
    . . . pictures? . . .
    Nov 2013
    us
    the port slips over 1.5" pvc and glues on the back side.
    this is a stock google photo. Our pool wall is smooth!
    [ copyrighted photo removed - Admin ]
    Nov 2013
    us
    Hi Ben,
    I trust you view the pic, before it was deleted. (I did not see any mention of a copyright on google images, but no harm )
    From what you saw, how do you suppose one cuts the flange fitting from the 1 1/2" pvc, still ends up with a clean pipe end, and still has enough to glue a new slip on flange onto it?
    Have you possibly seen this done before.
    Do you suppose in the alternative, it can be epoxied from the inside?
    I have epoxies some hard to reach hot tub fittings.
    tips appreciated!
