Re: Sealing a leaking return port flange on gunite pool
Hi Ben,
I trust you view the pic, before it was deleted. (I did not see any mention of a copyright on google images, but no harm )
From what you saw, how do you suppose one cuts the flange fitting from the 1 1/2" pvc, still ends up with a clean pipe end, and still has enough to glue a new slip on flange onto it?
Have you possibly seen this done before.
Do you suppose in the alternative, it can be epoxied from the inside?
I have epoxies some hard to reach hot tub fittings.
tips appreciated!
