I have a 15' Intex above ground pool.
I have covered it for the Winter.
I have not drained the water, as my intent is to just shock it again next Spring/Summer.
Water is VERY expensive and I'm on a budget.
My issue is that no matter how tight I tie off the cover, it "floats" on top of the water.
Then the water in spots, slowly overtakes the cover, and it starts pulling in the cover from the sides.
Is there a trick to this, or should I let some water out of the pool, so that the water level is below the cover?
Any tips would help.
