Results 1 to 10 of 18
Thread: Question-How Reduce Power Costs?
    Katy, Texas, USA
    Default Question-How Reduce Power Costs?
    Advice please, new to pools, had ours (~26,000 USG salt water) 10 months now. Power rates here in Texas went up ~50% this winter, not looking forward to power bill for AC & pool this summer !
    Read tips on www.poolsolutions.com including one on mail filter pump HP and power costs, I have "standard" 2.0 HP main filter pump (Pentair WhisperFlo Model WF-28, Service Factor = 1.1) and probably small plastic lines between pump and pool and thus high backpressures due to friction et al. Not good.
    1) Curious (as too late to change), how do I measure pipe sizes is it OD or ID?
    2) To reduce power cost assume I assume not worth changing this "big" pump out as less than 1 year old?
    3) Water circ back to pool via white plastic nozzles at sides of pool and in spa that are screwed onto the plastic pipes. Seems to me that if I removed these nozzles then back pressure would be significantly less and thus pump volume would be significantly higher and thus I could run pump less per day?
    4) OK so removing nozzles would be unsightly, how about I just drill them out to 1" holes?
    5) Any other power saving ideas?
    Thanks in advance . . .
    Round Rock, Texas, USA.
    Default Reduce power cost options
    I live in Round Rock Texas, and last fall I switched from TXU to "Direct Energy". The rates from the same pole are about 20% lower after the switch.
    Also see my post in this section about 2 speed motors. Upgrading to a 2 speed motor will have a fast payback period. Just increase your pump on time to move the same volume of water every day. Look at the curves on competitive pumps. Lowering the pump backpressure at low speed helps the water flow better, so the GPM reduction at low speed is not nearly as dramatic as the speed reduction of your electric meter.
    Use high speed for extra skimmer suction, bottom feeders, vacuuming, but not every day.
    Just pay attention to the low speed priming issue.
    I think that this 2 speed motor idea is as big a secret as using bleach, borox, and baking soda as compared to a dump truck full of chemicals ($$$$) from the pool store.
    Jim
    Katy, Texas, USA
    Default
    Jim, thanks for support.
    Power supplier, good point, I live in Katy Texas and used www.powertochoose.com and my zip code to compare power rates and switched from Reliant to Gexa Energy which is also is cheaper I think than Direct Energy, plus wehen I signed up for auto monthly billing against my credit card they gace me 2000 Continental Airmiles plus airmiles for each monthly charge. Problem is all the providers rates went up significantly this winter.
    Katy, TX
    Default
    Quote Originally Posted by Katy-Texas
    Not to threadjack, but howdy neighbor!
    Michael
    mas985's Avatar
    Pleasanton, CA
    Default
    Answers to your questions:
    ID but usually not exact to the pipe size.
    It could still be worth it. Especially if you can get a rebate from the power company. Some states offer up to $300. Even so, pay back could be less than 2 years.
    Yes, you could first try to remove them and see if your pressure gauge drops.
    You may want to see if you can purchase new fittings first. If you cannot, then consider drilling them out. Most returns are 1", so it seems odd that they are so small.
    My guess is your turnover rate is about 3 hours? If so, try running the pump for only 3 hours a day. 6 during heavy swimmer loads.
    Mark
    Honesdale PA
    Default Something to consider
    Just a simple thing and not very significant. When the pressure increases the power consumption (current) to the pump decreases. Try putting a clamp-on ammeter on the pump line and see what happens. Look at the current (amps) full flow then blocked. Turns out that when the flow is totally blocked the power consumption is at a minimum. No water flow = no work done = low power consumprion. Specific to a centrifugal pump. On to the issue....I bored my return nozzles out to cut the pressure but I also know I don't have to run the system as long and therefore save some energy. Me thinks we're talking details that won't make much difference in the monthly $$ electric bill. As much as I'm being a monkey and tracking all this stuff, I haven't done it for this issue. So.....just my thinking and fodder for discussion.
    Default
    Good suggestions! 2 speed pumps are the way to go! How many gallons is your pool? 2hp sounds HUGE. I run a 20,000 gallon pool with solar heat on a 1 hp Super Pump (Hayward) and I run it on low-speed 99% of the time.
    Orlando, Florda, USA.
    Default
    Now I'm concerned about my pump.
    Our pool is close to being done and the builder has a 2.5 HP Hayward Super 2 pump setup.
    We have a Hayward DE 6020 Filter. A Rock waterfall, 3 foot shear decent fall, 4 returns, 2 spa jets (in pool), skimmer and vac line. Will be getting solar later this year (9 - 10 panels).
    Pump is same ground level as pool and furthest point away from pump is maybe 100 feet. PVC pumbing is 2". Pool also is 15 X 30 freeform but only 3 ft to 5.6 feet deep. I'm guessing gallons at maybe 13K.
    Should I have builder take out pump and replace with smaller, or can I (as some said in this thread) simply run the pump for only 3 hours a day.
    I should also say salesman told me I "didn't" want a 2 speed pump when we were getting started.
    Thanks for any advice.
    W Bell
    Orlando, FL
    mas985's Avatar
    Pleasanton, CA
    Default
    Because of the water features and vac line, you will need heavy flow some of the time. This means you have two choices, multiple pumps or a 2-speed pump. For a 2-speed pump, the turnover time is twice as long as that of the high speed but the energy use is about a third. So overall energy savings is about 30%. Going form a 2.5 Hp to a 1 Hp pump will save you close to the same (depending on pump) but you may still need a bigger pump for the features and vac. So either way, you should have significant savings which will pay for itself in not too much time at all.
    kaybinster Guest
    Default Two more options
    If your utility offers it, you might want to switch to time of day billing. Obviously you will need to do an analysis of how much electricity you use at various times of day. In NJ, time of day billing gives you cheap power during off-peak in exchange for expensive power peak periods which are M-F 9am-9pm. I have an electric heat pump to heat the pool and run the pump and the heat pump at night and on weekends when power is cheap.
    Another option is to install a PV solar electric system to generate your own power. I have a 10 kw system which generates about 12,000 kwh a year. Check out the threat on solar water heating where I described the system in more depth.
