The photos load fine, but they don't show the installed liner, illuminated by the light. I think that would be the relevant photo for this situation.
Sorry I do not have photos of the liner at this time.
I just figured I would post the one that I have of the build process for now.
The bad weather is supposed to blow out of here tonight and I will take additional photos tomorrow of the finished pool and liner.
Everyone have a happy turkey day and be safe.
Sincerely Vic
Hello all
Hope everyone had a great Thanksgiving.
Well I was able to vacuum up the pool and take some photos of the liner, stairs and finished job.
First I will start with the liner as this is where my concerns was with the pool bottom surface finish.
Some of the photos are before I cleaned the leaves out so forgive me.
http://s29.photobucket.com/user/cuda...?sort=3&page=1
As you can see there is one wrinkle in the liner that I can hopefully get out in the spring by lowering the water level and using a couple toilet plungers to work it to the outer wall panel.
This second set shows the stairs.
I am not sure what to think as the stairs have to land on top of the metal wall panel so you cannot make them any lower than they were installed. Is it possible that they installed the wrong style stairs? It almost looks like these are supposed to be used with a finished concrete coping where the liner bead is instead of the white bull nose coping.
Finally here are a few of the finished pool and spa photos.
Overall on a scale of 1 to 10 ten being the best I would give it a solid 8 maybe 8.5, I am again a bit of a perfectionist so if it were perfect I would give it a 9.5. Any thoughts and comments are welcome.
Sincerely Vic
